2007 LS beginner mods
Old Nov 25, 2012 | 06:08 PM
CmeBckKd's Avatar
Yea this site has helped me with some quick tips & inspiration. I attempted these mods after reading a few "how to" threads. Live & learn. It's about 50ish here so I didn't know how the cold temp would effect it. I let the tail lights sit over night after I did the final coat of tint. This morning I did the clear coats & compound. Side markers are almost done & look so much better.
Old Nov 25, 2012 | 06:26 PM
skyline26's Avatar
if you let paint dry before the next coat it will turn out bad, you will have to re-scuff the surface again for the paint to adhere to, thats why you dont wait long between coats
Old Nov 25, 2012 | 06:28 PM
CmeBckKd's Avatar
Dang! Now I know.
Old Nov 25, 2012 | 09:19 PM
CmeBckKd's Avatar
I think the side markers came out great.
The screw holding them in was a little rusted &kinda stripped which was a pain. Took only 2 easy coats of tint to get them blacked out. I replaced the bulbs with silver star 194 since passenger side burnt out.
Old Nov 25, 2012 | 11:56 PM
Temp & humidity are key factors...
Lower temps & /or higher humidity will require longer 'flash' times. You can also pre-heat the part(s) with a heat gun, or hair dryer.
Also best to keep paint Inside warm house till you use it..
Looks pretty Good
Old Nov 26, 2012 | 12:43 AM
CmeBckKd's Avatar
Yea I kept the chemicals inside while using them. The spray flow was difficult when it was cold. I'm learning as I go. I'm so glad you guys do "how to" posts with pics.
Old Nov 26, 2012 | 05:57 AM
Rattle can painting below 60 degrees= Bad results. Best to do this stuff during the summer.
Old Nov 26, 2012 | 11:45 AM
CmeBckKd's Avatar
Turn signal trouble
Now my left turn signal is going faster than the right. What's the deal?
Old Nov 26, 2012 | 11:56 AM
skyline26's Avatar
Your bulb might be on its last days
Old Nov 26, 2012 | 11:58 AM
CmeBckKd's Avatar
The front turn signal? How do u get to it?
