headlights not clear
Old Aug 15, 2012 | 11:58 PM
skyline26's Avatar
Hello all,
I have the Depo headlights but i started to notice that they arent very clear anymore. they arent hazy but they kind of look just dirty :s any suggestions on how to clean them up and prevent this from happening again? I went out and bought PlastX or whatever its called and it doesnt seem to be doing anything..
thx
Old Aug 16, 2012 | 12:41 AM
You might be getting dirt &/or moisture in from where the bulbs connect.
Old Aug 16, 2012 | 12:46 AM
skyline26's Avatar
so would replacing the plug help or can we get new rubber or foam seals?
Old Aug 16, 2012 | 12:52 AM
"If" the dirt/haze is indeed inside, then getting new boots should help with sealing out further crud....
But you would still need to remove the headlights & gently wash 'em out with warm (dish) soapy water..& rinse well.. Then air dry, or help w/hair drier..
This happens often on newer Harleys & a quik wash & new seal does the trick.
Clear as new...
Old Aug 16, 2012 | 05:39 AM
skyline26's Avatar
removing the headlights?! oh man putting them in was a mission! haha
Old Aug 16, 2012 | 07:17 AM
swerv0428's Avatar
You need to eatablish if the dirt/haze is inside or outside. Are the lights pitted? Is the lens still smooth?
It may be inside but make sure before you go and pull the bumper again.
Old Aug 17, 2012 | 12:17 AM
I have to say, you are the 1st one to post with this issue, TIKO ?
But if it's inside, least you been there before..
HotHHRSS
Aug 30, 2009 07:49 PM
Black Beauty
May 17, 2007 06:07 AM
RUDEINC
10
Aug 31, 2006 06:18 AM
EZ4U2CHere
10
Jul 7, 2006 05:06 PM
