My $1.08 Lower Grille Mod on Shaggy and Shaggy Has New Teeth
Old Jun 3, 2007 | 08:10 PM
  #111
Goose's Avatar
NHHHR- My "grill" pops out on the bottom corners sometimes also...for the most part it stays but is not that tight on the bottom corners. I do not have it bolted, just the clips. I cut the corners on the top at an angle so the mesh does not even touch the bolts...
How did you guys fit the mesh over the bolt?
I have a few more pieces so I can make another...I feel during the winter there may have to be something to secure the bottom as snow hitting up there will push that screen right out
Goose
Old Jun 3, 2007 | 08:16 PM
  #112
Memphis_HHR's Avatar
Use some wire cutters and cut a hole for the mesh to fit over the bolt and put a flat washer and nut on it. If you piddle with it enough and get it "formed" right, it'll stay in place.
Old Jun 3, 2007 | 08:26 PM
  #113
Goose's Avatar
Did you cut a hole on the side of the mesh or did you cut out a "doughnut hole"?
Goose
Old Jun 3, 2007 | 08:33 PM
  #114
Goose
Snip out a hole like a donut to fit over the nut.
Old Jun 3, 2007 | 08:41 PM
  #115
Black Beauty's Avatar
I`ve had mine in for the better part of a year, no problems with popping out, snow, or stones, it`s the best, cheapest mod that has come along.
Old Jun 3, 2007 | 09:56 PM
  #116
Goose's Avatar
How is your grill attached BB? Do you have the bolt on or anything clipping on the bottom?
Goose
Old Jun 3, 2007 | 10:18 PM
  #117
Originally Posted by NHHHR
No matter how much I bend, it still kinda pops out and is going to scrape against the radiator piece on the left side. Anyone have any solutions or worries for this?
Never had a problem with mine when it was in. So far no complaints from TCRNCOB or Don Battista, both were a g2g install I did for each, and to my knowledge they have not bolted their's down.
Old Jun 4, 2007 | 12:51 AM
  #118
FinkHHR's Avatar
Scaleguy,
Can't wait to see pics of your color matched 3-bar grille with mesh. A few members here have the chrome 3-bar with mesh, but I have really been wanting to do a color-matched version with mesh to tie-in the theme with the lower grille (although mine would be dark silver instead of your black).
Anyways, i am hoping to get a idea of what it might look like based on your ride.
Have a good one - Joe
Old Jun 4, 2007 | 05:47 AM
  #119
Posts #33 & 43.
This is a How-To thread, you have go back to the beginning and read what others have said/done.
Old Jun 4, 2007 | 06:05 AM
  #120
Goose's Avatar
Thanks :twothumbs
I don't know how I missed your posts that you mentioned...that's why I asked
Goose
