New headlight assemblies .
Old Jan 5, 2024 | 04:01 PM
The SS grilles are longer , not shorter.
Old Jan 10, 2024 | 09:28 AM
heathenhhr's Avatar
I bought those same headlights, just haven't put them in yet... you beat me to it!
Old Jan 18, 2024 | 06:55 AM
Beejmamdude's Avatar
Originally Posted by donbrew
Oviously after market. I was meaning that the SS grille is sorter because the bumper cover id higher for the intercooler.
I have never seen a stock grille with a cold air intake hole.
So my rear hatch doesn't lock when I lock the rest of my doors so I remove the relay for the rear hatch door. Locked my keys in the car one day and only way to get them put was to cut away a hole in the grille and pop the hood. I lost the pieces I cut out and so I just put the circle thing there just because I thought it looked better than have an odd shaped hole in my grille.
Old Jan 18, 2024 | 07:03 AM
All lights on. Including the halo/angel eye projector fog lights and the light strip on top of the headlight assemblies.
Just the running lights
Emergencies on. Cant really notice but the fog lights are also turn signals and the fog lights are led projectors with a halo light around them that halo is a running light and a orange turn signal
Old Jan 18, 2024 | 07:07 AM
Notice the grille is for SS, it does not fit to the bumper.
actually donbrew it does fit to the bumper but when I swapped out the cooling fan and radiator I didn't bolt the hood lock in the correct position and I hand not gotten around to fixing it.
Old Jan 18, 2024 | 07:09 AM
Well the reflection is weird but you get used to it
Old Jan 18, 2024 | 07:56 AM
You need to remove fuse #11 from the underhood fuse block, then your hatch should work properly.
Old Jan 18, 2024 | 08:24 AM
fuse 11 is empty
Old Jan 18, 2024 | 10:03 AM
How does opening the hood get the doors to unlock ?
Old Jan 18, 2024 | 10:08 AM
I’m wondering the same thing FMG
