New headlight assemblies .
Old Jan 22, 2024 | 05:16 AM
PulpFriction's Avatar
How to unlock an HHR with a piece of paracord:
Old Jan 22, 2024 | 06:29 AM
How does opening the hood get the doors to unlock ?
Originally Posted by Oldblue
I’m wondering the same thing FMG
In this case, he reinserts the rear hatch relay and opens the hatch.
Old Jan 22, 2024 | 07:46 AM
Makes sense.
But if it was me, since you’ve got a spare relay on hand, why not just have a spare key stashed there instead ?
Old Jan 24, 2024 | 09:02 AM
Fuse #11 inhibits the hatch lock. It should be empty if you want to lock it. Pulling fuse #10 would disable the relay. I have no idea why it would not lock if the touchpad works, the "lock" just disables the relay.
If could get the hood open you could manipulate the hatch relay to open it. Why not use the key to open the driver door? A locksmith will sell you a credit card sized plastic emergency key for the door.
Old Jan 27, 2024 | 12:10 PM
Beejmamdude's Avatar
the Rear hatch does not. You can just go and pop it open even if all the doors are locked. Unless I remove a relay or the fuse
Old Jan 27, 2024 | 12:12 PM
  #26
I fixed the hole and the fraudulent "SS" BADGE now i just need to give my car breast cancer. Cut em off then fix the bumper cutout
Old Feb 4, 2024 | 11:22 AM
  #27
If there is a fuse in position #11 in the under hood fuse box the hatch WILL NOT LOCK. Here is a pdf of the circuit, if anyone cares.
liftgate.pdf
Old Feb 4, 2024 | 11:34 AM
  #28
Thank you, Donbrew. Appreciate your support!
hhrumadbruh
Jan 21, 2023 08:31 AM
Lethal Tendencies
Nov 4, 2020 02:42 PM
Lethal Tendencies
Mods - Exterior
18
May 14, 2020 01:07 PM
Ron S
Nov 17, 2017 08:20 AM
pyro panel
Mods - Exterior
Jan 23, 2012 05:28 AM
