Headlight Bulbs
Old Nov 10, 2017 | 01:35 PM
Ron S's Avatar
Headlight Bulbs
Has anyone experimented with H13 led headlight lamps? They are supposed to be plug in, they also talk about built in cooling fans. I am not sure about the clearance behind the headlight housing and the inner fender well.
Thanks
Old Nov 10, 2017 | 02:05 PM
Cat Man HHR's Avatar
I have to ask. Why do you need headlights that bright?
It use to be people running with their high beams on were a pain.
Now it's common place to have bulbs like this in a low beam application, which are a pain.
Just my 2 cents.
Old Nov 10, 2017 | 04:18 PM
I haven’t had them , but I’ve been happy with the lights I have and can’t justify the expense.
Old Nov 10, 2017 | 04:42 PM
Just my 2 cents.
Then again, Ron might be more interested in the long life that LED usually offers.
Old Nov 10, 2017 | 08:01 PM
gio89kid's Avatar
I have used them, plenty of room for the fans. Cool looking led white light.
They do not produce good light output with the reflector, but I have seen new ones that have come out that are supposed to be better and adjustable somehow.
They ended up going out on me and I put in Phillips extreme bulbs and they produced the best halogen output I could get from our reflectors.
I now have a HID retrofit projector and the light output rivals any new car on the road.
If I were to do it again, I would buy the new led projector from morimoto and retrofit it in and have basically lifetime headlights with great light output.
By the way...
Never put in HIDs in a stock reflector you will blind people, the LEDs can do that too.
HIDs require a wiring harness and ballast that produces 35k volts which can be dangerous, and the bulbs aren’t that safe either.
That being said, if you use HIDs they can be safe to work on while off and use gloves when touching the bulb incase it breaks, and never look into it while it is on, it’s very bright and can output UV. Luckily the UV is contained in the bulb and if any were to escape it would have to go though the projector glass and then the anti UV coating headlight lens on your car.
but, on the other hand...
An LED projector has all of the benefits of HIDs, but they are very safe, they directly plug into your stock wiring with an adapter and without the need for a ballast or wiring harness, they do not produce UV and do not have a bulb to replace.
The only down side for me is that the bulb can not be replaced so it can not be easily repaired when it goes out, but they are supposed to last forever.
Not sure if you wanted to be educated on headlights, but there you go. :)
Old Nov 10, 2017 | 08:52 PM
Trex08's Avatar
I should also add that although leds look cool from the outside, they do not produce anywhere near the depth or detail of whats in front of you that standard halogen bulbs do. They wash out everything with even light, so there is less shadowing, which minimizes your perception of what you're looking at. This is why I only use leds for brakes and markers.
I would love to use leds for headlight because of their long life, but I'd rather see better.
Old Nov 17, 2017 | 06:11 AM
Ron S's Avatar
Update, I went with the standard lamps. With luck they will get installed today if something else doesn't pop up in the way. Thanks for the input. Maybe by the next time they will be improved. I am getting too old to lay on the ground to work on a car. It's getting too hard to get up.
Old Nov 17, 2017 | 07:48 AM
Wait!
We're supposed to be able to get back up?
Must'a missed that memo...
Old Nov 17, 2017 | 08:13 AM
I go in from the side, no need to lift the car or lay down on the job!
Old Nov 17, 2017 | 08:20 AM
aradmahogany's Avatar
Same here I just go in from the wheel well. Also, check your headlight adjustment they might be too low! Unless you put LED bulbs in a housing made for them, the light projection is terrible. When Gregg was at the doctors office (dealership) after his accident, they gave me a loaner 2016 corolla that had LED lights standard. In an OEM application, I have to say they were the BEST headlights I have ever driven behind, and offered great visibility.
goetylsd
Maintenance and Upkeep
59
Jun 19, 2017 05:55 PM
Skatetheglobe
Jan 1, 2009 06:37 PM
andoll83
Nov 24, 2008 10:48 PM
m0rie
Jul 12, 2008 09:14 AM
laylowcustoms
Mar 2, 2008 08:38 AM
