opinions on IPCW lights.
At the risk of reprimand I will tell you what I think, hope it doesn't offend anyone. I absolutely love my lights, and will be buying one more set from Maggie at Race and street, stellar customer service.
gotcha . Top ring powers bottom. Makes sense.
ON
OFF
Right Hand Upper
PLUGS [If you look close, you see a "bulb" insert on the end of the wiring, simply, remove remove bulb, remove stock housing, line up LED with the mounting bracket inside the back hatch, secure, and PLUG in. The little red/black wire is for the reverse light RED RING of LEDs for running lights.. Easy as pie!
If you look closely at the following picture, second from left is a Silver Ice Metallic HHR 2LT with the Clear... For reference.. That was DJR1973's 2LT before he went SS..
OFF
Right Hand Upper
I stuck with the red. The others were to "ricey" for my taste. There is a jumper wire that connects the top and bottom running lights together. I've had mine since early 2008. I got one of the first sets released.
