Preping exterior for rockers?
Old Jun 11, 2011 | 08:18 PM
lucasbuck's Avatar
I ordered a set of chrome rocker panels and door handle covers. Is there anything I should clean\prep the surface with before sticking them on?
Also, even though it's not exterior, I'm going to throw this out there. I was reading about how to install scripts in the interior. Is that adhesive promoter 3M good to use? Do you just wipe down the area with it first? I didn't know if excess (outside where you were applying the script) would screw up the surface of your vinyl. As always, thanks for any info!
Old Jun 11, 2011 | 10:11 PM
Just wipe them thoroughly with Grease & wax remover, or Rubbing alcohol.......
Old Jun 12, 2011 | 09:06 PM
lucasbuck's Avatar
Thanks for the info!
gary47speed
Mods - Exterior
Jul 29, 2012 05:07 PM
centaur1129
Mods - Exterior
Apr 10, 2012 10:45 AM
conn.rod
10
Jan 27, 2011 11:34 AM
