Mods - Interior Discussion related to the looks of the interior of the HHR.
Best way to tie into dash lights
Old May 12, 2013 | 07:08 PM
nybble's Avatar
I'd like to add footwell lighting when the dashlights are on. I had something similar in my Corolla, which was easy to tie into (ring around the cig lighter).
Any suggestions on the best circuit to hop into? Probably something in the waterfall block?
Old May 12, 2013 | 07:24 PM
Dracos's Avatar
Do a search here for "footwell lights". One of the slots in the interior fuse block can be used, but I don't remember which one off hand.
Old May 13, 2013 | 12:33 PM
Putter's Avatar
I tapped into the back of either the hazard light button/traction control button on the waterfall. Just unplug the connector, turn on the lights, and use a multi-meter or test light to check. Been connected there for years with no issue.
My stuff dims with the dash lights.
Old May 18, 2013 | 04:14 AM
hhrumadbruh's Avatar
You see the button that closes when the door shuts? Tap into that. It's great because it's right next to where you want the light
ppaul
Maintenance and Upkeep
37
Nov 24, 2025 06:54 PM
brainless twit
Jan 14, 2011 10:02 PM
Hotrodbob
Nov 24, 2010 11:16 AM
ezeerider
Jun 3, 2009 07:24 PM
HHR-DICK
May 13, 2009 05:07 PM
