Make sure you do both sides at the same time, I pulled the air baag fuse when I did mine.
Originally Posted by whopper
(Post 593160)
You might want to consider disconnecting the battery in the trunk. Messing with airbags is not recommended unless you know what you are doing. And disconnect the NEGATIVE battery cable - not the positive.
