removing airbag to paint?
Looking to paint to match controls on steering wheel, checked out the how to followed the directions to the letter, put a alen wrench into the hoie started pushing on the clip inside and, the airbag moved a little over on each side but won't come off
what next......?
looking for help!
jeff
Transformer HHR
what next......?
looking for help!
jeff
Transformer HHR
You might want to consider disconnecting the battery in the trunk. Messing with airbags is not recommended unless you know what you are doing. And disconnect the NEGATIVE battery cable - not the positive.
disconecting battery...
thats correct, and i am going to disconect the battery thanks for your interest
every little bit helps, rather not paint in the car looks better removed
and done right.
jeff
and done right.
jeff
If your airbag is moving when you insert your allen wrenches, you are on the right track. Push the wrench a little harder and try gently pulling out on the airbag. Mine literally fell out in my hand. I had to catch it.
You can then access the screws to remove the parts you desire to paint.
After removing those, you can sit the airbag back in place (without snapping it in) wile you paint and never have to unplug it.
