Mods - Interior Discussion related to the looks of the interior of the HHR.
static cling window tint
Old Aug 18, 2013 | 05:29 PM
hhrumadbruh's Avatar
Has anyone used this?
I'm trying to figure out the best mixture of water/soap or other products to apply to the window that let me move the entire piece freely while I set it in place.
Old Aug 18, 2013 | 05:43 PM
Grizzly old man's Avatar
At one time I had a small body and radiator shop. The idea was to buy a few repairable wrecks and fix them during the off season from my roofing job.
I ended up being a general repair, body, and radiator shop that had so much outside work I barely got my own stuff done.
So yes I have used the plastic window tint. I discovered it was simplest to remove the glass lay the plastic and put the glass back in.
Yes, it is a lot of work but it will look the best in the long run. I would wash the glass with denatured alcohol then immediately apply the plastic. I used Stanley razor knives and replaced the blade for each window sometimes I'd use more than one blade for just one window.
I also discovered that it helped a lot to have the shop uncomfortably warm while applying the film. Also I would always use a lot of bunched up clean shop rags to support the glass on the bench.
I've wondered how the new metallic window tint is done, probably the same way I guess but I have never had any to play with.
Old Aug 18, 2013 | 06:50 PM
If it's "static cling" any fluid will defeat the cling part. If you are talking about the most common type, the directions usually say to use plain water to activate the glue on the film which in turn acts as a lubricant until it dries.
When all else fails I usually find the directions that I threw away with the bag and the receipt and read them.
I'm talking about the removable static cling. It's more of a rubber than the thin plastic stuff that you typically think of when you hear "window tint"
http://www.windowfilm.com/NEW_PAGES/cling_tint.html
Old Aug 18, 2013 | 06:54 PM
Haven't had the box in over a year I think.
And no, you can still use water and soap and even hand sanitizer to apply the static cling stuff.
Old Aug 18, 2013 | 07:54 PM
Fox Hat's Avatar
Don't waste your time on "static cling" tint. If it looks good it will only be the first time after that will look like a pimply derriere.
Just pay a pro. and do it permanent.
Many can be found here:
http://www.tintdude.com/forum/index....tdude_com.html
Old Aug 18, 2013 | 08:06 PM
I don't want it permanent though. $20 and doing it myself is much funner and I get the experience.
Old Aug 19, 2013 | 09:22 AM
walterpalmer's Avatar
Many years ago I used it on a van we had. It absorbed the (Illinois summer) heat and cracked the glass. Maybe glass or the film has changed since the early eighties, but I would not do it again.
Old Aug 19, 2013 | 03:58 PM
MsBecky's Avatar
Hey sport , it would be a service to the site for you to give us a report on your experiment .
Hypostasis ( Tint my windows for 20.00 with static cling tint )
Observation ( 20.00 cost & DIY )
Experiment ( Do the install )
Conclusion ( ?)
Then you can write a thesis on this type of window tint ........
Old Aug 20, 2013 | 12:29 AM
Just add a couple drops of mild dish liquid soap into a spray water bottle..
Clean glass, & spray soapy mix heavily on glass & cling as you remove the protective layer. once on, spray the back & using a squeegee work it out easily..
The fog in it will dry clear in a couple days.. I don't think 'cling -tint' on windows that roll down would be advisable tho..
I use it on (my home) rear storm door glass, w/excellent results.
