what am i doing wrong
Well i have a 2010 hhr, I'm swapping out the insides into my 2008 hhr.
I'm haveing trouble with the front door panels not fitting right.
The rears went right in, But the front WOW pitb ??
Please i do need some help
Thank's
Delta HHR
Thank's
Delta HHR
Well I think you're running into a "backwards compatibility" issue, there are some differences between the door panel assemblies, like the master switch assembly in the 2010 doors. With the change from dash mounted window switches to door mounted in 2009, it looks like some changes were made internally in the doors.
Here's the 2010 door...
http://parts.nalleygmc.com/showAssem...rimLevel=14420
And here's the 2008 door....
The 2010 was totaled , My 2008 inside looks like the people before me grew
peanuts in it, Yes that DARN BAD. With coffee stains all over the place even the head liner.
So with the black interior, WOW what a swap.
So i started the swap, carpet, headliner, seats, panels as much as i could.
Swaped out the door latches, window motors. shifter also
Door panels pitb so i will just paint the old ones.
Put in the 2010 raido went to my old dealer, They couldn't program the raido.
Bcm didn't see the up dated raido, So i cleaned the old raido and reinstalled it.
I did it, I replace both upper and lower dash panels to black.
I transferred pass.air bag cover to black.
Now i have a black dash panel.
When done i will post the finished picture soon i hope LOL
Not that hard at all. Just remember were you'r screws go after words.
But the 2010 hhr was close by so i didn't have to remember LOL
You must remove the "A" pillier tho for them screws under them
The dash is plastic, So pulling and yanking might break it.
Just don't yank the dash out because of the sensor in the middle of dash.
Pass. air bag, The bolts under and behind the glove box.
REMEMBER to disconect the batt. Before playing with the air bag.
