Plasti-Dip/Plasti-Dipping A sub-forum for the discussion of Plasti-Dip and its various uses.
plastic dip side glass
Old Nov 4, 2014 | 10:08 PM
lunchbox's Avatar
I wouldn't worry about the dip coming off. I have been dipping my back glass for a couple years now, and have had no issues with car washes. PlastiDip (if applied correctly) is very resilient, and will only peel off if you want it to.
As Frenchy42 mentioned, you can paint over the dip, but it does reduce the peel-ability of the dip, just make sure you have a decently thick base to spray over.
Old Nov 5, 2014 | 11:36 AM
JAN67's Avatar
I have read on here that it's easier to remove the dip if you have a thick base. Apparently a thin base of dip is a real SOB to remove.
Old Nov 5, 2014 | 03:24 PM
Frenchy42's Avatar
What you have to do is just make sure you put it on thick. When I did my stripes, i did about 3 normal coats, with about 5-10 minutes in between, and then a super heavy coat on top of those. If you are masking, make sure to peel it while the dip is still wet, or it will come up with the tape.
Old Nov 8, 2014 | 06:38 AM
walkowg's Avatar
will post new photo when i do the rest.
Old Jan 21, 2015 | 07:38 PM
walkowg's Avatar
Well took it to the next step today . Photo could be better but I only a phone camera with us.
Old Jan 22, 2015 | 12:45 AM
An interesting look, I've always thought that GM could have blacked out the B and C pillars from the factory anyway.
Old Jan 22, 2015 | 07:01 AM
Make it appear to be a long floating roof, but old school cool!
Old Jan 22, 2015 | 09:33 AM
I would prefer gloss black. Do they make plasti-dip in gloss?
Boydie
Originally Posted by walkowg
on sunday i sparyed my side glass flat back plastic dip. I like how it turn out .
Old Jan 22, 2015 | 10:42 AM
No, not as such, but they provide a spray can "glossifier" that you use as a top coat over the matte finish to provide a glossy finish - ie: https://video.search.yahoo.com/video...2Cm%3Asa&&tt=b
Old Jan 22, 2015 | 02:31 PM
walkowg's Avatar
843de thanks for the link fix
gcrabill
Jul 28, 2008 08:48 PM
