plastic dip side glass
I wouldn't worry about the dip coming off. I have been dipping my back glass for a couple years now, and have had no issues with car washes. PlastiDip (if applied correctly) is very resilient, and will only peel off if you want it to.
As Frenchy42 mentioned, you can paint over the dip, but it does reduce the peel-ability of the dip, just make sure you have a decently thick base to spray over.
What you have to do is just make sure you put it on thick. When I did my stripes, i did about 3 normal coats, with about 5-10 minutes in between, and then a super heavy coat on top of those. If you are masking, make sure to peel it while the dip is still wet, or it will come up with the tape.
No, not as such, but they provide a spray can "glossifier" that you use as a top coat over the matte finish to provide a glossy finish - ie: https://video.search.yahoo.com/video...2Cm%3Asa&&tt=b
gcrabill
Jul 28, 2008 08:48 PM
on sunday i sparyed my side glass flat back plastic dip. I like how it turn out .
