06 hhr 2.2
Old Mar 10, 2026 | 10:42 AM
boatmoter's Avatar
06 hhr 2.2
Hi all, have my 06 HHR, auto. 2.2, transmission (just started) shifting hard like I just put a shift kit in it., I serviced the transmission and filter and replace all shift solenoids a little (over a year ago) & used AC Delco Dextron 6 fluid. I just got done checking fluid level and it is perfect. no engine mounts are broke. I also blew out the transmission module by testing it with my scanner while engine was running About 8 months ago, bought one and it was programmed by the vin and sent back plug and play. worked fine. any ideas? I do have a bidirectional scanner, there is no codes
Old Mar 10, 2026 | 01:00 PM
Check the TCM ground wire, check the ground from the transmission case to the radiator cradle.
double check the pins in the TCM connection.
Old Mar 10, 2026 | 01:33 PM
boatmoter's Avatar
Thanks. I will do that tomorrow. morn.
ENASNI TILLER
Jun 15, 2024 08:46 PM
Jace1283
Jul 20, 2023 04:15 PM
Drivesfed
Drivetrain (Excluding Engine)
12
May 11, 2022 04:43 PM
Mrmihalko
Sep 28, 2021 12:42 PM
