06Hhr Service traction control
Old Nov 23, 2013 | 07:02 PM
Big lions fan's Avatar
My service traction control light come on for no reason then just turn off when you turn car off.when light come on when you turn car it will shift hard help. codes are poo11 co561 u2107
Old Nov 23, 2013 | 07:12 PM
to the forum!
Before we can be of any help, there's something you have to do first.
Head to your local auto parts store(Napa, Advance, Autozone, O'Reilly, etc), and have them "pull the codes".
They'll do it for free and give you a printout of the stored trouble codes.
When you have the codes in hand, post them in this thread and we'll be able to point you in the right direction.
Without the trouble codes, we'd be guessing, and guessing wastes your time and money.
Old Nov 23, 2013 | 08:11 PM
It does comes on for a reason; it needs to be serviced. It goes off when you turn the car off because there is no power to the DIC display panel.
Please get more information and get it to us, like engine size, mileage, last brake inspection, Check Engine Light. Most probable is you need a brake job. If it's a 2.4L maybe cam actuators. Don't know, don't have any info
Old Nov 25, 2013 | 12:46 PM
yes sometimes check engine light come on but when i have it check out dose not help me.lt 97280 is 2.4 changed cam actuators.
Old Nov 26, 2013 | 10:58 AM
Like 843de says, you gotta get the codes and post them - any suggestions would be a total guess.
Old Dec 7, 2013 | 11:14 AM
06hhr
the codes are poo11 co561 u2107
Old Dec 7, 2013 | 12:56 PM
Great - you got the codes!!!
From what I can see, you have either 1 or two problems:
u2107 - "Lost Communications with Body Control System" - check the fusebox under the hood for a good connection - I believe it plugs into a big receptacle below it. Also check that the plugs adjacent to it are securely attached to the computer boxes (it may have generated the other two codes)
P0011 - "P0011 Intake Camshaft Position (CMP) System Performance" - that points to the Intake Camshaft Actuator Solenoid (solenoid, not "sensor) - and is well detailed here on how to replace it, along with the part numbers etc.. - https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
c0561 - " System Disabled Information Stored" - can be generated by the problem related to the P0011 code on occasion.
So check the connections first and go from there.
Tip for you: get used to using the SEARCH tool at the top of the page - ie: enter a code and do a search for it, then do a lot of reading, which is often quicker finding what you need rather than awaiting a response to your query.
Old Dec 7, 2013 | 01:54 PM
Could be one of the Cam Position Sensors, but not likely.
Old Dec 7, 2013 | 04:05 PM
True dat. One thing that comes to mind was if the solenoids he replaced already were OEM or were some after market ones. Me, I'd stick with the GM ones.
Old Dec 7, 2013 | 04:12 PM
ladydi's Avatar
Traction Control Light
I have a 2006 that had the same problem. Took it in and had it scanned. I needed to have an Intake VVT Solenoid replaced. No more problems.
Fox Hat
Feb 7, 2014 07:39 AM
bigmac993
Feb 5, 2014 08:59 PM
oldracer
Jan 18, 2014 07:21 PM
mrarff
Jan 29, 2011 05:26 PM
Li'l Hearse
Apr 16, 2009 07:33 AM
