07 Chevy HHR won't crank not even A click.
Old Mar 1, 2025 | 01:31 PM
Kyle Tay's Avatar
The grounds behind fuse box where attached to body by firewall going to try battery whith 13 or better volts if it won't restart I will open fuse box
Old Mar 4, 2025 | 11:22 AM
Kyle Tay's Avatar
HHr won't crank.
Really need to fix.been over 1 year trying please help.I took fuse box apart no burt wires nothing melted no loos wires looks good no power too starter solenoid.
Old Mar 4, 2025 | 11:36 AM
When you reassembled the fuse box did you tighten the 4 bolts until you heard clicks?
Old Mar 4, 2025 | 12:38 PM
Tighten these four bolts!
Old Mar 4, 2025 | 12:58 PM
Kyle Tay's Avatar
  1. I tightened fuse box until it clicked
Just tried to start and nothing and the service air bag light came on can't hear fuel pump now. It
Old Mar 4, 2025 | 01:36 PM
I suggest you take the fuse box apart and check for bent or pushed out pins in the connectors
Old Mar 4, 2025 | 03:13 PM
merged
Old Mar 6, 2025 | 01:33 PM
Kyle Tay's Avatar
HHr no crank
I took the fuse box out everything looks good.Idid not take the top off the piece below it has slots you pry out seems like the top part of the slot will break how do you do this
Old Mar 6, 2025 | 03:15 PM
Kyle Tay's Avatar
Sorry for posting new thread I am not good at this how do I take top of fuse box off the lower part with out brakeing it thanks for your help
Old Mar 6, 2025 | 03:38 PM
Gently pry on the plastic tabs
