08 Chevy HHR computer ruined by shop??
Old Jun 15, 2022 | 10:44 AM
CEL only means a code is set, there is no reason to assume it is the same code as before.
Old Jun 15, 2022 | 11:56 AM
iluvmud's Avatar
agree 100% just not loving this rabbit hole
Old Jun 19, 2022 | 01:35 PM
iluvmud's Avatar
And here we go.......... ran the code fore the new CEL.......... P2270- which points to O2 sensor #2, it was replaced literally 3 months ago with an AC Delco one. im sure there is a warranty at the mechanic shop where they replaced it. anything else it could be?
Old Jun 19, 2022 | 01:52 PM
You're 1 digit short on that code. DTCs are 1 Alpha character followed by 4 numeric characters.
Old Jun 19, 2022 | 02:05 PM
iluvmud's Avatar
corrected it, thanks its P2270
Old Jun 19, 2022 | 02:12 PM
  #26
So if you replaced the sensor, and it didn't fix the problem, then it's something else.
From obd-codes.com
The causes for this DTC may include:
Exhaust leak near O2 sensor
Contaminated or failed HO2S2 (Sensor 2)
HO2S2 wiring/circuit problem
Loose installation of HO2S2
Fuel pressure incorrect
Faulty fuel injector
Engine coolant leak
Faulty purge solenoid valve
PCM has failed
Read more at: https://www.obd-codes.com/p2270
Copyright OBD-Codes.com
Old Jun 19, 2022 | 02:46 PM
  #27
Fuel pressure test
inspect the under hood purge valve, it should be closed.
inspect the flex pipe. Cracks
Old Jun 19, 2022 | 03:03 PM
  #28
Minor correction: OBD codes start with a letter then a 4 digit hex code, some do have letters in them. I think it's hex, maybe octal.
P2270 points to #2 O2 sensor STUCK LEAN. That means that either the sensor is bad or the is an electrical problem.
I would check the wires and connectors to the #2 O2 sensor. Especially suspecting pin A and B
Old Jun 19, 2022 | 03:13 PM
  #29
Yes, there are a handful of those oddball codes. Thanks for the correction.
Old Jun 19, 2022 | 05:52 PM
  #30
iluvmud's Avatar
I will start here, I did remove the flex pip a few months ago thinking that was the problem but it was good, so ill take this to the mechanic who did the work and see what they say.
