08 HHR SS won't start
I recently changed out my headlights for HID'S. And now for some odd reason my car won't start. The fuel pump sounds like it kicks on and it will run for a second or two when I spray starting fluid into the intake. It just seems like I am not getting fuel from the injectors. I checked all my fuses and swapped around relays and still no go. It's my daily and need all the help I can get
Could be a coincidence. Have you done anything else recently? Like clean and re-oil your air filter? It won't start, so you won't be able to see a check engine light. Do you have access to a code reader?
My 08 SS won't start
i checked all the fuses and they all were good..I also switched out a couple fuel pump relays and no difference. the only fuse that blew was the headlight inline fuse and I replaced that one
