144k my first trans delay/slow shift
No codes, no lights, have a basic Matco code reader with me, no faults…massive delay and no engagement between 1-2 was very concerning, almost turned around but seeing a dying relative in FL so carrying on…hopefully a fault will trigger soon….it’s just weird that it has only happened during start and drive then hasn’t happened the rest of the drive cycle.
I have opened the transmission and removed the shift solenoids, 2-3 shift solenoid is visibly burnt on the inside, I’d say that’s the reason. Luckily not melted to connector. Made it to Florida and back but problem was still present after almost every restart, if you experience what I experienced shifting, change them out before it leaves you stranded, and before it throws a fault, solenoids cheap, transmission expensive.
My 2009 LT Panel has about 125,000 miles and it is not shifting properly. Seems to not want to shift out of first or second gear. Check Engine light is on. Code pulled at Advance Auto Parts is P0757 Shift Solenoid valve 2 Stuck ON.
Any suggestions or advice would be appreciated. I was gonna drop the pan and replace the filter this afternoon and add new Royal Purple ATF. Does that sound like a good idea???
Thanks,
Chris
Hi, Any chance you have the part numbers for the transmission solenoids?
Thanks,
Chris
Thanks,
Chris
P0757 is actually 2-3 Shift Solenoid valve perfornmance-no third or fourth gear. There is a possibility there are broken or loose wires involved (between the trans and the TCM).
Replace the 2-3 shift solenoid and the 1-2 solenoid. Royal Purple is even more expensive than the recommended Dexron V!, whatever you use it should be a Dexron certified synthetic.
