1600$ at Chevy and still no fix need help
Old Sep 30, 2019 | 07:07 PM
Ark4utx3's Avatar
Traction control is still on and that's the print out from the dealership today. And once car turns off all codes vanish and check engine light is off then about one hr of driving everything comes back.
Old Sep 30, 2019 | 09:20 PM
You need to get a scanner and read the codes every time the CEL lights up to make sure they are the same codes. Of course, when you turn the engine off the codes disappear. Ignore the ones that are "history".
You can get a ELM 327 device that talks to a smart phone for as little as $6.00. https://www.ebay.com/sch/i.html?_fro...m+327&_sacat=0
OBD2 codes are numbers assigned to individual tests. When a test fails the CEL is illuminated and the test number is posted. Each test is run after a certain criteria is satisfied, some must fail twice in a drive cycle , some must fail on consecutive drive cycles before they cause the CEL. That is why they don't pop up right away
You should check the wires in the area marked 1 in this pic, they sometimes get frayed and cause the troubles you describe.
James Bienvenue
Tires & Wheels
10
Oct 24, 2018 10:21 AM
kamikaze3557
12
Apr 29, 2018 07:47 PM
mominpa39
Jan 2, 2017 01:59 PM
Agpullen
Feb 6, 2016 05:53 PM
oldracer
Dec 18, 2015 10:03 AM
