2.2 engine the difference in years 2007 /2009
Old Jun 15, 2015 | 10:37 AM
adan76's Avatar
Hi I want to change engine 2.2 2007 to 2009. Are there differences about which I need to know .
Old Jun 15, 2015 | 10:58 AM
Depends on if the 09 has Variable Valve timing or not .
You can verify this by looking at the left side of the valve cover and confirming if it has or doesn't have the solenoids to the left of #1 spark plug. The 07 should not have them but double check.
And pardon my manners , welcome to the site!
Old Jun 15, 2015 | 11:47 AM
It will depend on which vehicle the replacement engine comes from.
If you're trying to swap HHR engines, then it probably won't work. The 2009 HHR was a flex fuel engine. The 2007 was not.
Note** Just saw you are located in Poland. Sorry but I don't know if the above info will be the same for European HHR's.
Give this link a read. https://en.wikipedia.org/wiki/GM_Ecotec_engine
Old Jun 15, 2015 | 11:55 AM
adan76's Avatar
Thank you.
So there are two versions of the engine to 2009.
Ok I feel I need not Variable Valve Timing.
Is it only this different?
Sorry for the errors that operates google translate.
Old Jun 15, 2015 | 12:15 PM
The engines have to be the same configuration, and preferably the same year, otherwise the electronics (Engine control Monitor) and numerous other connectors/sensors will not be compatible.
Old Jun 15, 2015 | 12:20 PM
adan76's Avatar
I found the same engine, only to 2009.
As I said, the seller has the motor shaft with one sensor on the head.
and I have one sensor shaft!
Old Jun 15, 2015 | 12:27 PM
adan76's Avatar
Old Jun 15, 2015 | 02:17 PM
Is that your old 07 engine?
Old Jun 15, 2015 | 02:21 PM
adan76's Avatar
No, this is new engine 2009
