2.2 LT oil in spark plug well
Old Apr 28, 2014 | 11:02 PM
Lucky's Avatar
The small rings are for the bolts. If the originals bolt seals look good you can reuse them. The covers are different from 2.2 to 2.4 but the operation is the same. They have the same number of bolts. But the 2.2 don't have the actuators to unplug.
I just had the cover off my 2.4 and broke the zip tie rasters that hold the wiring harness to the valve cover. Not a big deal but when I find the part number for them I will let you know.
Old Apr 28, 2014 | 11:40 PM
pstar's Avatar
I changed the oil on Saturday and changed the air filter and plugs on Sunday. I wonder if it's from the oil change? I scrubbed off some grime between the plug holes but I didn't see any fresh oil on top of the valve cover. The plug well in question is the 2nd one away from the oil fill. Hmm. Thanks for the heads up.
Old Apr 29, 2014 | 06:41 AM
-md- HHR's Avatar
ON some of the 05-06 heads the casting process would leave voids in the head, and coolant or oil can / could work its way through the head and fill the spark plug holes.
In 03-05 L61s this is becoming very common on engines with 150,000 or more miles on them....not saying that this is dirrectly your issue, just added some more info on the subject.
Old Apr 29, 2014 | 08:59 AM
07azhhr's Avatar
I would think if it were due to a sloppy oil change then the closest cylinder would have oil in it. Especially if enough oil were spilled to get to the next cylinder over.
Old Apr 30, 2014 | 12:44 AM
Originally Posted by donbrew
I don't believe there is a difference between 2.2 & 2.4 except internally (size pistons, VVT pre 2009 etc.)
2.4 does have bigger pistons + longer stroke crank. (stroker)..(beefier block internally as well..)
"No Replacement for Displacement"....
06chevyHHR
Maintenance and Upkeep
Aug 22, 2014 10:27 AM
rickschr85051
Mar 3, 2014 04:51 PM
hhrpdc
Aug 14, 2012 11:08 AM
kmcrae476
11
Aug 10, 2011 07:15 AM
