2006 hhr basket case *need some help*
Old Jun 22, 2020 | 04:38 PM
I think the issue with these codes is that they pertain to sensors that are not present on an HHR, therefore, these tests should not be taking place. Maybe someone put the wrong ECM in it.
Old Jun 22, 2020 | 05:06 PM
Could be, does the part number match
https://www.gmpartsgiant.com/oem-che...ol_module.html
Old Jun 23, 2020 | 04:07 PM
Joshua Oleyar's Avatar
thank you all for the helpful responses! I cleared codes and these two popped back up p0106, p0368. im looking into the ECM now!
Old Jun 23, 2020 | 04:14 PM
The P0106 points to the MAP sensor, read up on that, here...
https://www.obd-codes.com/p0106
P0368 points to the cam shaft sensor, note wiring harness and what to inspect
https://www.obd-codes.com/p0368
I don’t see why you are going to the ECM
Old Jun 23, 2020 | 04:16 PM
12599714 ecm
Old Jun 23, 2020 | 04:28 PM
Correct one for your 2006 HHR
Send hellshotrod a PM he might have a good used one
Old Jun 23, 2020 | 04:59 PM
got it. thank you. MAP out, looking at Camshaft sensor wiring now.
I guess i saw in a earlier post something about ECM because of all the strange codes getting thrown... so i just wanted to confirm correct ECM
Old Jun 23, 2020 | 05:20 PM
Camshaft sensor "b" being the exhaust.
Old Jun 23, 2020 | 07:19 PM
Could you please confirm your engine, 2.2 or 2.4? Thanks.
Old Jun 23, 2020 | 08:58 PM
2.2l
