2006 hhr basket case *need some help*
Old Jun 23, 2020 | 09:10 PM
Interesting, the 2.2 doesn’t have a camshaft position sensor, because it doesn’t have VVT. So check that MAF wiring
Old Jun 23, 2020 | 09:28 PM
Joshua Oleyar's Avatar
I removed and cleaned MAF to see if that helped and quickly inspected the connector but i will look harder at the MAF wiring.. Im probably going to pick up a new MAP to weed that out. And i will double check the engine size. im almost positive its 2.2 but ill check again tomorrow. thanks again for all the help!
Old Jun 23, 2020 | 10:20 PM
Lonwane's Avatar
One look at the exhaust pipe tip will tell you.
2.2 is 2"
2.4 is 2.5" and chrome
Old Jun 23, 2020 | 10:39 PM
Exhaust can be changed. If the engine has VVT valves, it's a 2.4.
Old Jun 24, 2020 | 08:04 PM
confirmed it to be 2.2L. replaced MAP sensor. checked plugs cylinder 1 and 4 have oil on them. kind of loosing hope.
cleared codes, let it warm up. tried to put up and back a few times,and tried to rev up to 4k and CEL came back on, engine power reduced.... same MAP, cylinder misfire codes again.
Old Jun 24, 2020 | 08:05 PM
  #26
oh and crank case code again
Old Jun 24, 2020 | 09:38 PM
  #27
What crankcase code?
Old Jun 24, 2020 | 11:31 PM
  #28
P0315 "crankshaft position not learned" means somebody replaced the ECM and did not learn the crankshaft sensor.
P0335 and P0336 are crankshaft sensor codes 335 is the circuit 336 is performance
P0016 "crankshaft-camshaft position correlation" means bad timing chain.
I went back rereading this thread 3 times, there is no previous mention.
Old Jun 26, 2020 | 07:24 PM
  #29
camshaft code.... so sorry about that. i mixed them up p0368
  #30
replaced MAP sensor and still getting p0106??
