2006 HHR fan not turning off...
Hello,
This morning two hours after I had gone into work, I came back outside to the fan still running under the hood. Of course, when I tried to get into it later to go to lunch, the battery was dead. This is not the first time this has happened. My mechanic has put in a new battery and changed out a blown EPS fuse, but every so often I find the cooling fan not shutting off, my battery dead, and EPS fuse blown when someone jumps my car. Any idea why this keeps happening?
Thanks
Thanks
I agree with changing the relay if the new relay starts sticking again then I would look at the cooling fan. It maybe pulling high amps welding the contacts in the relay. As for the eps fuse that happens when it is jump started improperly.
