2006 HHR starting problem
Old Aug 25, 2010 | 08:07 PM
Lucky's Avatar
you will still need to replace the fuel pump to fix the lean code.
Old Dec 5, 2010 | 07:06 PM
meistromichael's Avatar
Just had this exact same problem on my 07 LT w/105,xxx miles. Replaced the fuel pump myself with one out of a salvage with 38,xxx (I know, probably not the best move, but only cost me $40). Not a hard process if you're a little mechanically inclined and have a jack and some stands and basic tools (15 mm socket, flathead screwdriver, hammer). Only took me about 1 1/2 hrs.
Not the ideal solution, but will work.
Old Dec 5, 2010 | 07:56 PM
Don06's Avatar
At 135K, your fuel pump is likely on borrowed time. A leaking fuel injector could also cause the pressure drop and decreased mileage but it should show up as a rich condition. Isn't there also a relief valve on the injector rail to return to the tank?
If you're planning on running the car to 200K, you might want to change pump and injectors.
Old Dec 5, 2010 | 11:05 PM
Lucky's Avatar
The fuel psi regulator (relief valve) is built into the fuel pump assembly. The hhr uses a returnless fuel system. And yes if it had a leaky injector it would probabiliy have a rich code and cyl. misfire.
Old Dec 6, 2010 | 08:00 PM
Don06's Avatar
It was easy to change on the fuel rail. A little harder in the tank. Wish they would have access panels so you don't need to drop the tank.
Old Dec 6, 2010 | 10:00 PM
Lucky's Avatar
That would be great. but in the end its all about the cost.
Dick147
Aug 20, 2013 07:45 PM
higs
Aug 27, 2010 09:22 AM
ChevyM84
Jan 24, 2009 07:02 AM
Flyboy6257
Sep 12, 2007 07:01 AM
smeedemann
Jul 31, 2006 03:47 PM
