2007 HHR Fuel Level Sensor
Old Apr 10, 2015 | 09:33 PM
luckybodog's Avatar
Originally Posted by donbrew
OK, did you read the tutorial on replacing the fuel pump. Your question is answered on the first page.
https://www.chevyhhr.net/forums/how-...acement-36541/
Yea I did thanks again for your help . Its good to have a place to go to get the answers for a particular vehicle. Regards
Old Aug 10, 2015 | 10:43 AM
HumbleTexan's Avatar
Unhappy Fuel level sensor connections?
OK, I read all the previous posts on this and could not find an answer to: "On the level sensor in the tank, to which terminal is the blue wire connected and to which terminal is the purple wire connected?" The terminals are marked 'I' , 'II', 'III'. 'I' is on one side, 'II' and 'III' are on the other, with 'III' being on the outer edge.
After replacing the fuel pump, the gauge reads empty; the message center says "Low Fuel"; and the DTC is: "fuel level sensor out of range".
I think I have tried every combination by just turning the key on and not turning off the MIL. The gauge did not react. Do I have to turn off the MIL before the fuel gauge will work?
Thanks Guys
Old Aug 10, 2015 | 11:37 AM
Try a battery negative cable disconnect for 20 to 30 minutes to reset the BCM and ECM to turn off the MIL, the fuel gauge if connected correctly should start working.
Old Aug 10, 2015 | 12:30 PM
Did you see the link in post #11?
The reply still stands.
Old Aug 10, 2015 | 01:59 PM
It says left and right. It does not say which side is the front.
Old Aug 10, 2015 | 03:21 PM
The photos don't help?
I have never done it, so that thread is all I got.
Old Aug 10, 2015 | 04:14 PM
Pictures don't show the wires to the sender. I'll try using all the different combinations while resetting the MIL between each combination. Let you know what I find.
Old Aug 10, 2015 | 05:45 PM
The hoses only go one way, I'd think if you had yours in hand and looked at the pics you would have a reference.
Old Aug 10, 2015 | 05:57 PM
Not talking about the hoses. Concerned about the wires for the level sensor. Found this on another thread. The "I" has the purple wire and the "II" has the blue wire. The "III" is not used. The ohm resistance between "I" and "II" varies between 40 ohms and 180 ohms. The wires DO NOT connect to the outer most terminals. They connect to the terminals closest to the center of the sensor.
I found on my '08 that the MIL had to be cleared before the fuel gauge would work.
Last edited by HumbleTexan; Aug 10, 2015 at 06:00 PM. Reason: additional information
Old Aug 10, 2015 | 06:01 PM
So we know it's the red wire, right Riggs not the blue wire? Riggs? Riggs?
I loved Lethal Weapon!
