2007 hhr ls
Old Apr 4, 2015 | 06:52 AM
luckybodog's Avatar
2007 hhr ls
Hi Everyone The HHR is hard to start it throwing cod P0171 The quy at the parts store said it was MAF sensor needed cleaned I did it. It did not help . I took the fuel line loose and there was no pressure . I turned the key on still nothing . Until I cranked it then fuel came out. Is the fuel pump bad? or just the fuel pressure switch? . Where is the Fuel pressure switch? Thanks in advance for your advice!
Old Apr 4, 2015 | 08:18 AM
Welcome to the site , type P0171 into the search window for some direction
Old Apr 4, 2015 | 12:34 PM
Lucky's Avatar
Welcome to the site the code you have is a lean code.
I would check fuel pressure first but you need to check it with a gauge and do a proper fuel system test.
Old Apr 4, 2015 | 03:48 PM
Welcome.
There is a link in my sig designed to help you! This one: https://www.chevyhhr.net/forums/how-...e-light-52828/
NEVER listen to the guy in the parts store! He usually knows less than you do.
GDZHHR
Apr 6, 2007 01:47 PM
karen1953
South East
10
Feb 5, 2007 08:19 PM
JB1
Sep 12, 2006 07:22 PM
