2008 2.2 starting hard, runs bad, surges
Old Jun 27, 2012 | 08:11 PM
63falcondriver's Avatar
Took the car to a dealership today. Since the fuel pump is under the extended warranty, I will let them do it. I am a little nervous about "others" violating my car....
The first dealership I called wouldn't be able to fix it before the 16th of July. Oh sure, I can just be without my car for three weeks or so. NOT!
I tried another place and they should be able to fit it in in the next couple days or so. It isn't really roadworthy as is so i just went ahead and dropped it off with instructions not to fix anything that wasn't covered by the warranty. I would have put the pump on myself just to have the vehicle back but it was about $234 bucks just for the pump assembly plus the time involved. And my hoist is being taken up by my Falcon at the moment. So we'll see what happens.
Thanks for the responses.
Old Jun 27, 2012 | 08:14 PM
Originally Posted by whitelightnin
Sounds like how mine was doing a while back. I had stuck valves and a short in the fuel injector.
Stuck valves as in "exhaust valves?" Did they have to pull the head to remedy that?
Old Jun 27, 2012 | 10:18 PM
whitelightnin's Avatar
It sat in the shop for about three weeks with no head. Warranty took car of everything!
Old Jun 28, 2012 | 07:07 PM
Dealership called today and said they had diagnosed it as the fuel pump and one was on order. So hopefully by tomorrow or so...
Old Jun 29, 2012 | 08:56 AM
Have you had any ETA from the dealership as to when the part will be in? Have they provided you with any updates this morning?
Old Jun 29, 2012 | 06:49 PM
Got the car back today with a new fuel pump. Runs well now. Still throws a #2 cyl misfire code but fuel economy and power back to normal. Service writer said the misfire code may be a sticking valve problem they've had on some of the ecotec engines. So that's the good news. On the way back from the dealership, Our Chevy Astro van blew out the drain valve and lost all of its coolant. Hopefully it didn't get hot enough to damage the engine. Found a new drain valve finally but part of the old one is stuck in there so I had to trailer the vehicle 20 miles back here to where I can get it up on the hoist to see if I can get the pieces out. Temps well over 100 degrees today. Miserable!
CruzHHR
Oct 1, 2020 05:54 PM
Gsus
May 5, 2014 12:42 PM
chefhhr
Dec 19, 2012 09:12 AM
Dyke67ny
Jun 27, 2012 10:34 PM
Old Ray
Jan 22, 2008 03:04 PM
