2008 Chevy HHR LS No Crank, No Start
Old Oct 14, 2025 | 05:35 PM
12.5 volts static . As Donbrew mentioned look for chewed wires, squirrels love the insulation, it’s soya bean based plastic, yummy!
Old Oct 14, 2025 | 06:13 PM
08CHEVYHHRLS's Avatar
Yeah, I'll try to look around. I might have to call a mechanic to come and take a look at it. I charged it and the battery is sitting at 13.4 volts now. The fuses aren't popped, so not sure what's next to do.
Old Oct 15, 2025 | 09:16 AM
Check the maxi fuse in the back by the battery
That red fuse on the right in this photo
Make sure these 2 cables are connected and tight, under the red cap on the under hood fuse box
Old Oct 15, 2025 | 09:34 AM
Yeah, I cleaned those connections and that fuse is good.
Old Oct 15, 2025 | 09:56 AM
Looking at the other pictures you posted, you’ve got a lot of rust and/or corrosion going on at those wire terminal ends. Any connection that looks crusty is a place for a bad connection. They all need to be taken loose and cleaned up.
(Remember: Always disconnect the battery before doing any electrical work)
Old Oct 15, 2025 | 10:24 AM
And now have a look at the starter, is that main wire tight is the smaller ignition switch wire tight?
Old Oct 15, 2025 | 06:55 PM
Hey everyone, I was able to get the car to start. Turns out it was a bad starter, even when hitting it, the starter did nothing. My mechanic was able to replace it and the vehicle starts up perfectly now. Part of the wire heading to the starter had to be replaced due to the corrosion as well. Thanks for all of your help. The main issue I have now is with the sticking key. The key no longer wishes to come out on its own, and I have to leave the cover of the access hole off to get the key out. I plan on bringing the car to Chevy tomorrow to have them take a look. The battery is fully charged. Do you guys have any suggestions or things I should note before bringing the car to Chevy? Thanks again for all of your guy's help!
Old Oct 15, 2025 | 07:13 PM
Well, you could check the recall status by looking at the link in my sig.
Old Oct 15, 2025 | 09:13 PM
It looks like my vehicle has had the ignition replaced based off the recall link in your sig. I will find out what Chevy says when I speak to them. Thanks for your help!
Old Oct 16, 2025 | 07:17 AM
Happy to read you got to the root of the problem and replaced the starter and the wires, here’s a link about a stuck ignition key issue
https://www.chevyhhr.net/forums/prob...gnition-49134/
Lube the shifter solenoid first.
