2009 HHR shimmies going down road
Old Aug 11, 2013 | 06:44 PM
bush's Avatar
I have a 2009 HHR I bought 2 weeks ago and it wobbles or shimmies going down the road. we just had the rotors turned. and it seemed ok for a day. But now its back at it again. Could the axles be bent? where do I go next. The dealer would fix it if we only knew what to do. I would like to hear from anyone that has had the same problem. WHERE DO I START NEXT?
Old Aug 11, 2013 | 08:53 PM
hurst2001's Avatar
possible are your rims balance ,that may be the problem start small work your way up...
Old Aug 11, 2013 | 09:54 PM
IgottaWoody's Avatar
Rotate tires front to rear and see if it changes
Old Aug 11, 2013 | 10:13 PM
Fox Hat's Avatar
Check that all the nuts are down tight too.
You didn't mention the mileage. With the ease of changing out rotors and pads and adding some appropriate grease to the sliders . I'd change them all out and start fresh
Old Aug 11, 2013 | 11:05 PM
to the forum!
There are a few possibilities as to what is going on, as pointed out in the posts above. But we need more information from you.
Does the shimmy occur during braking?
Is it only at low speeds, say less than 35 mph?
What sort of shape are the tires in?
How many miles are on the vehicle?
Old Aug 12, 2013 | 09:39 AM
jerrbear's Avatar
Did you use a wire wheel to clean off the backing plate? If not any rust or dirt left there could cause noise or shimmy.Rotors won't be sitting flat against the plate.
Old Aug 12, 2013 | 09:46 AM
If it does it all the time, take it back to the dealer and tell them to test drive it.
Old Aug 12, 2013 | 09:33 PM
blacky's Avatar
The first thing that comes to mind is wheels not going on straight. They may be hanging up on the studs. Lug nuts can loosen up tremendously in that case - see if you can turn any of them by hand.
Along same lines, stretched studs due to previous over-torque could lead to loose lug nuts.
Possibly crud in acorn nuts.
You might drive off and not have any gross symptoms - for a while.
Something like balance or a rotor surface problem isn't likely to go away for a day and come back.
Old Aug 12, 2013 | 10:07 PM
If the OP checks in again, I'd lay odds that they are experiencing a textbook case of brake judder. It's easily corrected, and easily prevented, we just have to wait for more info.
Mike Fortin
Mar 13, 2011 06:55 PM
Rachel Ann Bradley
South Pacific
0
Aug 21, 2009 02:32 PM
GDZHHR
Dec 7, 2008 05:23 PM
