2010 hhr power window issue
Old Jun 12, 2019 | 03:18 PM
Skribble93's Avatar
Hi all have a 2010 hhr lt and I am currently puzzled. The other day the drivers rear window quit luckily it was up I gave it no real thought and figured motor went then a few days later the passenger front quit neither now work from their own switch or the master all I hear is a light clicking at the switches. I pulled the panels and neither one gets power at all when the switches are activated I replaced the master being car came with a new one when I got it and have run direct power to each motor and they work and checked related fuses etc and still nothing being weather has finally gotten warm it is a bit irritating with only 2 working windows and being opposites at that. Can anyone maybe shine some light on a possible cause or solution?
Old Jun 12, 2019 | 03:54 PM
Broken wire in the conduit?
Old Jun 12, 2019 | 09:33 PM
Wet drivers door switches
Old Jun 12, 2019 | 10:06 PM
If fuse #36 underhood is good and the key is ON the green wires inside each door should be hot.
Old Jun 16, 2019 | 07:16 AM
Skribble93's Avatar
Driver switch is new being that was my original thought I have checked fuses and good on that end i'll check for power at the wires when I find time between regular upkeep on my other vehicles. Everything has to have issues at once lol
Old Jun 30, 2019 | 07:40 AM
Skribble93's Avatar
So was able to check wires finally and all fuses were good but no power at wire ran a jumper to the green wire from switched power at fuse block and windows worked fine not sure what happened no power before it even exits out to the door so at the moment each has a fused jump wire to the two that were not working other two still work fine as before. I'll try to trace out the wires best I can but alas car will most likely be getting sold in near future sadly family has outgrown it.
ufvj217
Mods - Interior
Sep 7, 2012 06:08 PM
got2boostit2
Apr 25, 2010 08:42 PM
da_dad66
2.2L Performance Tech
0
Apr 8, 2008 08:03 PM
HillsdaleHHR
17
Jan 8, 2008 12:04 PM
454Taylor
Mar 17, 2007 12:34 PM
