2011 HHR - U0073 code only during hot/humid weather
Hi All, I have 2011 HHR. For years now I have been getting a u0073 code during the summer, mainly on days when it is humid and over 85 degrees. This sometimes generates a u0100 code as well . What could be the cause? The error almost never comes up during the fall, winter or Spring.
U0100 indicates the problem is at the TCM. I would pull the TCM plug and inspect the pins for water or bent or not making full contact with the other half. Same thing with the ECM.
Check that all fuses are well seated in both boxes, especially #43 and #44 underhood. In my 2011 all of the fuses were loose.
