5-speed manual balky shifter.
Old Dec 16, 2018 | 06:28 PM
alexrckid's Avatar
noticed, recently on my 2006 HHr LT with a manula 5-speed that the shift linkage flles like it's getting tighter...harder to engage into gear. already pulled the shift boot off and sprayed some silicane lube oound the ball at the bottom of the shifter. helped for awhile but back again....any ideas..??
Last edited by RJ_RS_SS_350; Dec 31, 2018 at 10:12 AM. Reason: Typo triggered the family censor.
Old Dec 16, 2018 | 06:32 PM
May have one of the cables binding up. Could be that some of the lube you sprayed in there got on the cable end and freed it up for a while.
Old Dec 16, 2018 | 07:06 PM
Old Dec 23, 2018 | 09:55 AM
alexrckid's Avatar
2006 HHR LT manual shifter assembly
anyone, out there, have a blow-up of the manual shifter assembly where the shifter ball rotates..?? already checked the cables, they move freely but the shifter moves(even in the neutral gate) with some resistance, as if it's in need of some lubrication. i have already tried getting some light silicone lube to flow down, around the ball. this helped slightly but is not solving the problem. i have not been successful finding a diagram of the shifter assembly on-line nor a diagram in my Chiltons manual. i would have to imagine that a dealer's service dept has such info.
Old Dec 23, 2018 | 10:06 AM
Looked at some old posts and found this. Didn't see a good pic of where the ball sits in the assembly.
Aftermarket on top. Stock on bottom.
Old Dec 23, 2018 | 10:40 AM
The aftermarket shifter
From TWM
https://www.twmperformance.com/chevr...-short-shifter
I know this is for an F35 SS, but it might help to look at the pictures
https://www.chevyhhr.net/forums/how-...shifter-30554/
Please note these are short throw shifters for the SS , NOT the LS /LT .
Old Dec 23, 2018 | 11:06 PM
alexrckid's Avatar
found this specific instructions for a short throw shifter install for the 2.2 LT......these instructions explain alot about the stock shifter....thanks, everyone for your help....happy holidays to one and all.
https://www.twmperformance.com/image...ion-manual.pdf
Old Dec 30, 2018 | 06:40 PM
alexrckid's Avatar
ok, yesterday, with the great help of the manual for the TWM shifter, i took out, broke down and rebuilt the shifter mechanism in the console. not such a bad deal. come to find out that the mechanism is fine. reassembled for plenty of white lithium and TLC.....now that i knew that there's no binding, etc problems there, looked at where the cables connect to the top of the tranny. nothing evident there either but considering that even after doing the shifter all five and reverse still feel sluggish i decised to lube twhere the cables attach to the trans controls. this seemed to have fixed things. all shifts are now crisp and feel smooth. glad i first broke down the mechanism first to prove no problem there.....
Old Dec 31, 2018 | 09:24 AM
Awesome, glad it’s working better!!
Old Dec 31, 2018 | 10:06 AM
alexrckid's Avatar
me too.....was like rowing gears thru mud.....especially 2nd and 4th(both on the same cable).....
Voyager
7
Aug 7, 2014 08:07 AM
speedemon
Mar 18, 2012 08:18 AM
foofoomaru
Drivetrain (Excluding Engine)
Sep 9, 2011 12:27 AM
esmarkey
Dec 14, 2008 06:58 PM
Dmaeio
Jul 16, 2008 10:32 PM
