Abs Braking
Old Sep 16, 2006 | 11:54 AM
JOEK86's Avatar
Abs Braking
Any one experience the ABS kicking in for no reason when almost at stop? Of course I have the brakes on and am turning the wheel at the same time. Almost stopped and I can hear and feel the ABS.
Joe
Old Sep 16, 2006 | 12:16 PM
nfboy's Avatar
Joe
ABS is always there (If so equipped of course). How much you feel it depends on how hard you brake, speed etc. Do you brake extra hard at toward the end of your stopping "cycle"?
Old Sep 16, 2006 | 04:59 PM
JOEK86's Avatar
no, I don't......I wonder if the sensitivity is adjustable? It is definitely not working properly.
Joe
Old Sep 16, 2006 | 05:06 PM
trey1966's Avatar
Take it back to the dealer and tell them the ABS kicks in even when the tires are not slipping. That is the only time it should ever kick in.
There is no ajustability that you are going to be able to make.
Old Sep 16, 2006 | 05:09 PM
JOEK86's Avatar
I am calling Monday......but Iwoder how it will be fixed if there isn't any adjustment?
Joe
Old Sep 16, 2006 | 05:20 PM
trey1966's Avatar
Joe
A mechanic will be able to determine the problem and repair it. Chances are it is a sensor on one of the corners that is mis reading slipping.
As for adjustments, that is something that I suggest you stay away from. Not that there is no adjustment ability.
Unless you have experience in working on ABS systems, I would stay away from it. It's your life you are screwing with if you mess something up and can't brake. I have worked on plenty of brake systems replacing rotors, calipers, pads, drums, shoes, springs, you name it, but when it comes to the ABS part, I let someone who does it for a living handle it. Just my opinion...
Old Sep 16, 2006 | 05:25 PM
JOEK86's Avatar
I hear you, I wouldn't dream of getting into ABS, I know absolutely nothing about it!
Joe
IMPALADAKID
Jun 4, 2013 08:15 PM
CJ3
Apr 10, 2012 08:53 AM
us11csalyer
17
Jan 23, 2012 07:38 AM
'Lil Red Wagon
Dec 17, 2009 11:43 PM
Cajun
Jun 13, 2008 12:46 AM
