ABS Control Module for a 2011 HHR LT 2.4L
Old Feb 26, 2022 | 09:36 PM
jayco59's Avatar
Hello all,
I'm getting an error code that indicates the ABS control module has an internal fault and I'm trying to locate a replacement part.
The P/N is 20827127 but according to every parts place I've contacted it is back ordered.
On eBay I see an ABS complete system (Controller and pump) pn:20795797 which seems to have the controller attached to it.
Looking at the pictures of the complete module the Electronics seems to have the P/N 20799659.
Is this compatible with the 20827127 module?
Also I'm being told by the dealer that the module will require programming, Is this true for a used unit or only a new unit?
Appreciate any info that you can supply on this topic.
Thank You,
Jay
Old Feb 27, 2022 | 07:10 AM
For reference, your HHR is a 2011, yes you’ll need to vin match the part to your HHR
Old Feb 27, 2022 | 07:49 AM
jayco59's Avatar
Oldblue,
Thank you for responding.
Did you add the link to the manuals or is that some smart ad? I clicked on it and it wanted to install a browser extension. I have security concerns when I'm asked to install S/W from links I'm not familiar with.
Thx,
Jay
Old Feb 27, 2022 | 07:56 AM
No, I don’t add links. Disregard that.
In the RockAuto site you can click to get no when it’s back in stock
https://www.rockauto.com/en/parts/ac...ol+module,1844
This is how I put a link in ^^^^
Old Feb 27, 2022 | 08:04 AM
You could post up the actual error code number. Ex: P001, P002 etc. With the actual code number we may be able to tell you if you're chasing the correct fix.
Lots of times a description of codes like "internal fault" is not exactly what it means.
There are some pretty smart members on this site.
Post up the code number and let us help you.
Old Feb 27, 2022 | 09:14 PM
jayco59's Avatar
Fault code C0550.
Shop tech write up reads...
"Tech verified customer concern perform EEC test fault code C0550 present for ABS module
Performance performed pin-point test found ABS module has internal failure."
Old Feb 28, 2022 | 09:35 AM
PulpFriction's Avatar
I wouldn’t jump to the conclusion that the module is bad. (Maybe I should, but I wouldn’t, lol.) Power problems (like a bad ground) and transients (like a spark or a power surge or an EMP from a nuclear detonation) can destroy microprocessors but can also just cause a temporary hiccup.
Old Feb 28, 2022 | 10:47 AM
I know this is about the Colorado module, but check this video out
https://www.coloradofans.com/threads/code-c0550.415112/
Old Feb 28, 2022 | 12:01 PM
jayco59's Avatar
Appreciate the inputs. I may need to attempt a module repair if I can't find a replacement unit.
My main question is ...
eBay claims that the unit is compatible with my car but the numbers aren't the same, possibly the 20827127 is a replacement module for the 20799659 and either will work?
Thx,
Jay
Old Feb 28, 2022 | 12:23 PM
These folks repair your part, no coding required
https://repairlaboratory.com/repair-...torrent-1-900/
