ABS & Trac control light on...but not always
My ABS and Trac control light are on....but not always. Sometimes they shut off and both functions work when lights are off. When lights are on, both the ABS and trac control are non-functional (as you would expect). Problem seems to go away on dry days, but comes back on damp days....I'm thinking connection...dunno thou
Anyone else get this? Any ideas why the problem would be intermitent? Why would they be connected?
Any help is appreciated
Vehicle is an 06 HHR LT.
ESC & TRACTION Warnings May mean Low Battery
However, I continue to have a prblem with battery draining under short winter trips. Have now run an extension cord from the front bumper (where the block heater plug is) to the trunk (where the battery is). Installed a battery blanket and will permanently connect an automatic trickle charger when I find one. That way I can make my short trips and plug in my vehicle for a couple of hours to restore the battery a bit.
well....been a while, just thought I would update. Shortly after the lights stayed on all the time. Turns out it was the ABS sensor/bearing hub assembly (front right). For what its worth, the codes indicated it was the module itself, but the module was fine.
All's well that ends well....sensor was changed, and problem fixed
Just thought I would update just in case someone else runs along this issue.
purple people eater
Sep 17, 2016 01:07 PM
