ABS/Traction Control Lights, no OBD2 scanner codes
Old Oct 16, 2024 | 11:29 AM
Eman6213's Avatar
Had an issue with a leaking brake line previously. Got that fixed/replaced but now have ABS and Traction Control lights lit on dash... My OBD2 scanner doesn't show any codes for what the issue is... Any thoughts on what could be causing these to be lit? Thanks... 2006 HHR LT
Old Oct 16, 2024 | 11:37 AM
The brake fluid wasn’t bled properly.
Old Oct 16, 2024 | 01:22 PM
Does your scanner read ABS codes ? Most basic scanners and older units don’t.
Old Oct 17, 2024 | 08:23 AM
PulpFriction's Avatar
Prolly a C code, not read in many cheapie scan tools. Never had a parts store scan that didn’t include C codes.
Old Oct 17, 2024 | 03:21 PM
mistymountainlook's Avatar
Could be
Could be an ignition wiring harness problem. Good luck and thank you for keeping The Chevy HHR on the streets.
Old Oct 17, 2024 | 03:46 PM
It could be the abs harness wasn’t reconnected firmly.
Old Oct 17, 2024 | 04:35 PM
I’m sorry but, what ? Ignition wiring and OBD reading are not related. The OP is asking about brake issues and reading codes.
willyj8749
May 24, 2022 03:55 PM
501HHRPanel
Apr 22, 2021 09:06 AM
cgreco
Jun 26, 2016 01:09 PM
gio89kid
Feb 17, 2015 08:15 PM
bobnj
Jun 13, 2013 05:17 PM
