AC stops working and the temp gage stops working
Old Aug 4, 2019 | 03:52 PM
Originally Posted by donbrew
..... 178F is too low, the correct t-stat is 180F, the temp should always be above 180F after warming up.
Mine reads 178F a lot... Last time I had it in for a coolant system pressure check the mechanic said "You know your readout reads low" He had his unit hooked up, which reads off of the same sensor and my readout was 3 degrees lower than his calibrated scanner... Go figure.
Just saying this because mine reads the 178F but is not throwing codes, so there could be a glitch in the readout that isn't a "real problem" that would cause trouble.
Old Aug 4, 2019 | 05:29 PM
STony G's Avatar
I just dropped it off at the mechanics.
The temperature fluctuated between 175 and 203, mostly in the 180's, under the following conditions:
air temperature 98 degrees
11 freeway miles
speed at 60 mph
little to no traffic.
no A/C
Is the swing in temperature normal? just curious.
Old Aug 4, 2019 | 06:05 PM
Below 180F is NOT normal. Swinging between 180-190 is normal under those conditions.
The t-stats job is to keep the temp ABOVE 180F. The radiator and fan keep it below 219F. Airflow alone should keep it around 190F.
nascarguy3fan
Sep 17, 2022 11:24 AM
sidewheeler
Jun 23, 2013 07:25 PM
BookMark
Apr 29, 2012 09:36 PM
fjk08016
May 9, 2011 02:23 PM
chevyorange
Jul 1, 2008 05:40 PM
