Add ATF
Old Nov 10, 2019 | 11:15 AM
Nick Busch's Avatar
Exclamation Add ATF
My hhr has 69000 miles. I think I have a trany leak from transaxle seal or maybe pan. I wanted to add fluid is this fill cap? Its rubber and seems to have a small clamp on it. How to I get it off?
Trany fill cap?
Old Nov 10, 2019 | 12:07 PM
Is there a puddle on the ground?
The fill port, it just unscrews. It is plastic on the top of the trans driver side. I'm not sure on your pic that might be the extra outlet on the t-stat cover.
Check the level: warm, level, neutral/park,engine running. Remove level control bolt; tiny drip is full.
#10 on passenger side.
Old Nov 10, 2019 | 12:30 PM
Cat Man HHR's Avatar
I think your right Don. It does look like a cap and clamp for coolant.
He should start to look closer to the drivers side for the cap.
Old Nov 10, 2019 | 09:16 PM
Yep, T-stat rubber cover. Mine has same.
Don- nice 2nd pic !!
OKIE SS
Oct 1, 2020 07:22 AM
aradmahogany
Maintenance and Upkeep
May 20, 2018 09:03 AM
RJ_RS_SS_350
14
Aug 18, 2017 11:46 AM
manicrodder
2.2L Performance Tech
19
Mar 16, 2015 10:20 AM
