Aftermarket FOB issue
Hello, I'm recently new here, I tried searching for an answer but haven't gotten anywhere searching on here. I have a 2008 HHR Panel version. It does have the Info and reset buttons on the wheel. I found instructions on how to program a new FOB. The original FOB is broken. The logic board inside it is nonfunctional even with a new battery. I haven't been successful getting the new FOB to sync despite all the online Google uploads. Something is missing there somewhere. Does anyone know if it's REQUIRED to go to a dealer or not? The reason I ask is because I just don't know if it's worth the money since it has 437615 miles on it. Stock motor and tranny I might add. :)
Many thanks, Mike G.
SOME locksmiths are competent with fobs. If you can find one with a good reputation in this department, you could try buying a new one from them, but I would only do it with a guaranty that it will work. If it does, your old fob will prolly work too.
FallGuy2005
Feb 3, 2025 09:06 AM
