Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I will soon replace my '09 SS air conditioning compressor. Typically on major A/C work, I would replace the filter drier while the system was open. However, it seems the car does not have one. Can anyone confirm if the car has one, and where it would be?
It appears to be built into the A/C condenser.
Hope this helps
Hmm. I think typical best practice is to replace the filter drier when the system is open for major repairs. So would that mean you have to replace the condenser? That seems like overkill.
#27 is listed as an in line filter. Part number 52494593
Yes, that is the orifice, which serves double-duty as a filter. However, I'm referring to the larger soup-can-sized canisters full of desiccant to pull out moisture from the system. See the attached image
s an example.
All Google search results for AC drier are the condenser. Maybe it's the vertical tube built into the passenger side of the condenser. It doesn't appear to be serviceable.
I found a site that says if you have a dryer you need to have an expansion valve and if it has an accumulator it has to have a orifice tube.
I don't see an expansion valve but I do see a orifice tube. https://nostalgicac.com/driers-valves.html
