Air Filter change
Old 07-16-2010, 09:53 AM
rmsparks's Avatar
Air Filter change
I changed the air filter on my 06 HHR at 63K miles. After changing the filter, the check engine light and the traction control light comes on and has stayed on for 5 days now. Even the remote start dosent work. Any suggestions or cures or am I bound for the mechanic.
rmsparks is offline
Old 07-16-2010, 10:02 AM
solman98's Avatar
I'd start with making sure the new filter is sitting in the right. Then check to make sure you didn't unplug something. Then a trip to Advance or Auto Zone to get the code read to see what it is for.
solman98 is offline
Old 07-16-2010, 04:02 PM
Remote start is disabled w/ CEL.
jx3 is offline
Old 07-16-2010, 04:22 PM
You properly re-installed the MAP sensor?
Greybeard999 is offline
Old 07-16-2010, 04:46 PM
mikey12561's Avatar
Don't look at me. I have no idea my car is just so new too me. Only two days old.
mikey12561 is offline
Old 07-17-2010, 09:11 AM
jay loukakis's Avatar
I had the same problum whe i did my firs filte change it was not plugged in the fender opening as it was loose , now i have the cgs intake no problums now.
jay loukakis is offline
Old 07-19-2010, 02:44 PM
rmsparks's Avatar
Okay, I'm no mechanic. Is the mapp sensor that plug under the air filter? The last motor I worked on was a 327 in my 63 chevy pickup..
rmsparks is offline
Old 07-19-2010, 04:49 PM
Yeah..... the one just under the air filter...... I don't know if technically it's a MAP or MAF sensor but that's the one I meant.
Old 07-19-2010, 05:10 PM
JoeR's Avatar
It's the MAF. Failing to plug it back in WILL create issues, including a CEL.
JoeR is offline
Old 07-19-2010, 05:21 PM
Thanks, JoeR..... I'll try to remember that it's a MAF
Quick Reply: Air Filter change
