air flow sensor
1st Welcome to the forum.
Next-it is located in the rubber tube that mates the air cleaner housing with the throttle body.
There's a how to some where here. Trying to find it now....
https://www.chevyhhr.net/forums/show...=filter+change
Here ya go....
https://www.chevyhhr.net/forums/maintenance-upkeep-50/checking-replacing-air-filter-10757/
And
to the forum peachyma!
And
How hard is it to replace and what do I need to be careful about? I noticed a lot of oily gunk built up under the MAF sensor where the little hose from the engine connects. Is there any type of filter you can install to prevent oil residue from getting into the intake?
