Am I missing an O2 sensor?
Old Jan 5, 2017 | 10:59 AM
TerenceL63's Avatar
I just bought a '10 2.2L Flex Fuel model. My flex joint/pipe needs replacing and I just noticed that I have 2 cats on it. I also see that one of the O2 sensor locations is empty. Should I have 2? I want to find out before I proceed. Thanks so much for all input!
Old Jan 5, 2017 | 11:18 AM
Welcome to the site, You should have two O2 sensors, one upstream , before the cats, the other either in between the two cats or downstream after the second cat.
Like in this ads pictures
https://www.ebay.ca/itm/222223628991
I moved this to new thread, the other was five years dead.
Old Jan 5, 2017 | 12:16 PM
Some cars have the "pre" bung on the exhaust manifold. The "after" should be between the cats (only the first cat is monitored).
Is the bung empty, or filled with a bolt?
There should be a wire flailing about and a CEL.
The "pre" sensor monitors the Air/Fuel ratio, that data is used to adjust the injectors. If that one is bad/missing you will be getting horrendously poor MPG and a CEL.
The "after" sensor monitors the health of the cat. If it is bad/missing you would have a CEL.
If the bung is empty, that could be the noise etc. like a cracked flex pipe and a CEL.
Old Jan 5, 2017 | 12:25 PM
The 06's had the bung in the exhaust manifold, the '07's thru '11's had the 1st sensor in the pipe after the flex pipe before the cat.
And yes , Don the 2nd bung is after the cat or in the '08's thru '11's after the first cat.
I'm wondering if this is an after market piece with an extra bung?
Mike Fortin
Aug 8, 2011 09:39 AM
rudedog
May 17, 2007 06:14 AM
Steelcity
Aug 1, 2006 06:26 PM
wheelsee
Dec 30, 2005 01:37 AM
