Analog Fuel gauge not correct, all others working
Old Jun 2, 2023 | 02:43 PM
Basist_4's Avatar
Originally Posted by donbrew
Did this suddenly come up?
All of the information displayed on the I/P comes on the low speed GMLAN serial data line, 1 wire. So it must be the fuel gauge is broken, if all of the other indicator lights work. turn signal, hi beam, air bag, seat belt, batt, brake, ABS, traction, oil pressure and analog coolant temp.
The fuel pump/level sensor send data top the ECM the ECM sends data to the BCM that does calculation and sends data to the I/P.
The car is new to me, so I really am going into this with what little I have seen so far.
It really hasn't been driven much at all until I took possession, so i'm working through the bugs as I find them.
I still need to check the connection at the fuel tank (pictured above from Oldblue) before I can say it's the cluster istself.
But, as it has been said, it would be odd for only 1 gauge to malfunction...not impossible, just odd.
Old Jun 2, 2023 | 03:55 PM
greg8453's Avatar
Originally Posted by Basist_4
I went out today and loosened all 4 completely out and retightened them (Middle, top, bottom L, bottom r) a little at a time to try and equally distribute the load. I heard a little "crack" as some of the tension popped and resetteled.
I got them pretty tight, but I'm afraid to tighten them down too much...they're aluminum, right? I definitely don't want to strip them. Is there a torque spec for those bolts?
You need to reef on them.
Old Jun 2, 2023 | 04:08 PM
Was it working when you got it?
Since A; the miles to go and MPG work. The BCM needs to know the state of fill from the sender.
And B; all other gauges work. All of the data travels on the same wire from the BCM.
It has to be the instrument panel.
You have to use a computer to program a new I/P to the BCM. The odometer is stored in the BCM and will not display unless the part numbers match.
Old Jun 6, 2023 | 03:30 PM
Basist_4's Avatar
"REEF" on them??? that's a new term to me. Is that anything like an "Ugga Dugga"?
Old Jun 6, 2023 | 03:40 PM
Basist_4's Avatar
It's been like this since I got it a few weeks ago.
In the beginning (1st week), it wasn't working at all. Needle was all the way at the top of gauge (beyond full).
Lately, it's bounced back and forth between what appears to be an accurate reading and just above half full.
I filled up on Friday, so I know I have a full tank...when I started the car this morning, it showed just above half full. When I went to lunch it went to full tank (accurate).
At the end of the day, as long as the digital readouts are GTG, I'm not too worried about fixing the analog gauge. I'll just reset the trip and fill it up at around 300 miles. I appreciate your input and help with the troubleshooting!
Old Jun 6, 2023 | 04:31 PM
[QUOTEI got them pretty tight, but I'm afraid to tighten them down too much...they're aluminum, right? I definitely don't want to strip them. Is there a torque spec for those bolts?][/QUOTE]
Should be at least one loud crack. No spec beyond tighter than "I'm afraid they will strip". The point is that each fuse has 2 connectors under it that have to engage into clips in the wiring harness.
I would start with the bolt closest to the fuse or relay associated with the problem module.
Old Jun 7, 2023 | 08:20 AM
jimvw's Avatar
we use the German spec, Goodentite
Old Jun 7, 2023 | 01:33 PM
greg8453's Avatar
I'm still laughing.
Old Jun 7, 2023 | 04:36 PM
After you make sure that new part fitzentight!
emstess
Oct 10, 2021 12:23 PM
Doctuh
Sep 9, 2012 06:03 PM
Me and my monkee
Aug 3, 2011 11:04 AM
geg
Feb 28, 2011 06:18 AM
cwalker
May 18, 2008 01:23 PM
