Anemic heater (cold tootsies)
Old Feb 24, 2007 | 01:59 PM
  #41
mew7789's Avatar
Same Thing here. I noticed this right away. Face afire and cold feet and I am not cold natured. I did not think about the Mod although I will now. In my case I did not even have to get out of the car. First cold morning and it happened I thought, aw shucks..a bad actuator. So I stuck my hand under there and felt that blast of heat out of a duct that seemed to be aimed somewhere in front of my knees and thought, The guy who was in charge of aiming the foot vent skipped the part in school where they tell you heat rises....Ha Ha....
Old Feb 26, 2007 | 06:21 AM
  #42
GCarp's Avatar
Funny thing is ... My wife drives an '06 Pontiac Torrent and hers is WORSE. Must be a GM thing ... Kinda like that "New Math" thing... I haven't figured out how to fix hers yet. The vents are shaped different and actually don't even stick out past the side of the console. Go figger ... most of that warm air is heating the inside of the console.
G
Old Jan 4, 2008 | 01:10 PM
  #43
wingfeather's Avatar
I have cold feet, too
Looks like I'll be creating an air diverter of some sort...
Old Jan 7, 2008 | 11:15 AM
  #44
Goose's Avatar
Same here...awful heating for feet in the HHR
Goose
Old Jan 7, 2008 | 12:04 PM
  #45
Old Ray's Avatar
[QUOTE]
Originally Posted by Goose
Same here...awful heating for feet in the HHR /QUOTE]
wingfeather I have cold feet, too
What they said, big time.
Old Jan 7, 2008 | 05:56 PM
  #46
Old Ray's Avatar
My fix!
Parts used; two 2 inch gray plastic straight nipples for plastic pipe, one 33 degree black PVC elbow, glue (for plastic pipe but ended up using plastic emblem adhesive instead). Black, gray, and white plastic fittings are not necessarily compliable and will not always fit together.
Left (drivers) nipple shortened with elbow installed and right (passengers) nipple cut at a 45.
Installed: glued into ducts, left seems good, but right one I maybe should have use a black elbow. It’s kind of ugly.
Total cost; $ 10.00 cdn including the glue that I didn’t use. High from glue fumes…No charge
Total time; 10 minutes to find parts,
1 hour to visit with friends in hardware store,
20 minutes to install,
Two hours to get pictures into message.
I’ll let you know how it works.
Old Jan 7, 2008 | 07:30 PM
  #47
laborkei's Avatar
Man, I don't know...
At least you agree, it's Ugly.
Old Jan 8, 2008 | 06:24 AM
  #48
Goose's Avatar
Ugly but warm...GM retards who designed this need to be fired
Goose
Old Jan 8, 2008 | 11:12 AM
  #49
GCarp's Avatar
Some of the design (not just the heater) seems to be engineering student projects - not professional engineering.
Old Jan 10, 2008 | 10:22 AM
  #50
sky's Avatar
sky
Adjustable floor heat diverter:
material: 2" x 2" x 10' roof drip edge...$3.29 @ Home Depot
As pictured below:
1.) cut 4" long piece of drip edge & flatten raised edge
2.) mark & cut one side @ 2"
3.) bend uncut side to form a movable/adjustable hinge
4.) remove sharp edges
5.) attach with duct tape
I have one on each side and prefer to keep the right side nearly closed for more heated air to driver side.
