Another A/C thread
Old Aug 19, 2024 | 10:53 AM
The reason I asked about the compressor is because the fan switch sends a "ground" signal to the BCM when the fan is turned on. The BCM will disable the compressor if does not get that signal. Knowing that would help narrow the possibilities.
The compressor does not run unless the fan switch is turned on. Then you look for continuity between the switch and ground and between the switch output at the BCM to ground with the switch on (good continuity) and off (no continuity}.
The switch switches the path to ground for the fan motor. The hot side of the motor is always hot.
Old Aug 19, 2024 | 11:04 AM
Newb45's Avatar
Great info. I appreciate it.
Old Aug 28, 2024 | 09:11 PM
Newb45's Avatar
Alright, getting back to this. I got it to shut off while I was driving it. It would only work when it was pulling fresh air into the cabin. Pushing the reserc button would turn off the fan completely. Looking at it now, and I can't get the fan to shut off but it definitely blows harder when recirculating air vs. fresh air. I doubt that a blend door would shut off the fan and I'm fairly certain that the fan was shut off the time before when I was driving it.
Off to try to find a bcm pin out.
Old Aug 29, 2024 | 06:53 AM
Look in Donbrew’s signature for free information including wire diagrams
Old Aug 29, 2024 | 12:49 PM
Normally Recirc turns the AC compressor on. The AC compressor only runs if the blower is on. Description of operation is in your Owner Manual.
Sounds like some wires are crossed.
Old Aug 29, 2024 | 01:04 PM
Newb45's Avatar
Awesome, thank you.
RICKJF
Sep 2, 2021 09:23 PM
Solotreker
Jan 14, 2018 09:24 AM
Keenan2789
Jan 23, 2016 06:54 PM
kuzzins
Aug 7, 2011 03:16 PM
